And I am one tired Daddy!!! The hardest part was to pull the carrier back out,to change the shim pack for more backlash. That puppy was really stuck,even with the same shims! Luckily,I had a 1985 Truck Service manual,which had the 8.8 rear listed,so as to figure out how much shim to switch around,to get .008 more backlash. They had a nice chart in there that was dead on accurate. By now all joints were aching,and only wanted to do this one more time. In the end everything checked out,with a good tooth pattern. Tomorrow axles and lube go in. Time for a brew or two!!!!
