Hi guys,
Just removed the stainless steel MAC FlowPaths and had the ProStreets (model #6224 - $69 each) installed. If you're in Tucson be sure to use Exhaust Works...They do first class work. They mandrel-bent-fabricated flow tubes from the MAC "H" to the new Spintechs, welded my mid-"H" connection (which I had with only a clamp before) and did the mufflers and hangers for only $60 total (what I consider a good deal. The Prostreets require flow tubes to be done right because they are about half the width of the stock mufflers).
After the drive home I can tell you this:
SOUND
The sound is as loud and mean as the MACs were, so I'm happy about that...an almost equivalent sound.
DRONE
The 2-2.2k drone was reduced about 90%! Still a bit noticeable (because I know what to listen for) but not the least bothersome or painful. In fact the drone is much reduced over even the stock Bullitt mufflers.
VISUAL
The stainless MAC FlowPaths were little pieces of automotive art...rounded corners, smooth little neat welds. The Spintechs are ugly little alumized steel welded-up boxes. You look at it and all you see are welds. I tell ya, it's WORTH the ugly look, though!
PERFORMANCE
The car seems MUCH more rev-happy going up and down the RPM range. Seems smoother all-around.
CONCLUSION
I would like to thank Moljay for turning me onto this product and for all his patient email responses to my questions. The guys at SpinTech wanted to talk me into the larger, quieter mufflers (the Sportsman Street with 6 traps inside). Being ignorant of their product, that's what I would've bought...but Moljay saved the day by recommending the smaller Prostreet (3 traps).
Anyone looking for awesome musclecar sound, great perfomance and NO drone will be very happy with these! I know I am!
Dennis
Black#5578
Tri-Ax,DensChrgr100mm,MAC 2cat"H"& SpinTech ProStreets,FR 3.73&AlumDS,30mm H&R spacers,AutoLogic chip,MGW & Haney alum,FR500 wheel,SCHROTH red Harnesses
<font size=-1>[ This Message was edited by: Dennis on 2002-03-06 13:04 ]</font>
SOUND
DRONE
VISUAL
PERFORMANCE
CONCLUSION
Dennis
Black#5578
