1 - 2 of 2 Posts
How bad are these numbers?
-0.9 0.2 -1.1
CAMBER
3.3 0.3 3.3
CASTER ADJUST
0.43 -0.19
TOE
I know it relates to the allignment but could someone please explain.
I had a slow leak in one of my tires and went to Good Year to get it fixed. Upon inspection, my front two tires were worn to hell around the inside-outer edges. It was to the point that you could see the metal in the drivers side tire. I had to have that tire replaced at a cost of $230.00!! I paid about 150-170 for that same tire around three years back (GS D3). And the guy charged me $50 for a new allignment.
I guess tire roadside hazzard doesn't cover bad allignment wear on a tire.
This is interesting....
stock: Camber = -0.5 to -1.3
Caster = 2.5 to 4.0
Toe = .05 to .20
Excessive camber would cause the wear you are referring to, which is well within spec?
Only thing I see is possibly the amount of toe on the driver side was causing a pull scuffing the inside edge.(this is probably the statement they gave you to void the warranty?)
1 - 2 of 2 Posts
