1 - 13 of 13 Posts
1- 3.55 gears
2- (more a change to Ford than the Bullitt) keep the Bullitt wheels and other parts unique to Bullitt
3- more aggressive front fascia like the 01 or 03 Cobra
4- HID headlights, and LED tails, or at least LED chmtl
5- More rebound damping on front struts. Damn cars all float a lot
6- 10% or so higher durometer bushings all through the rear.
7- Cobra rear brakes (same, but thicker rotors).
1. 373 gears
2. fog lights
3. shifter..steeda
4. window tint
5 mach 1 chin spoiler
6.k&n filter
7. all the above :D
gears
heat extractor hood
better exhaust
tranny
sfc and lca
tune
sc
3.73 gears......Done
improved shifter.....Done
a real functional hood scoop....Done
Mach 1 grill delete........ Done
nice stainless steel LT headers....Done
a computer tune up........ Done
good set of tires.......Done
The perfect 2001 Bullitt,for me,......DONE DEAL!
Oh,and most important....I done it all meself!
three hot females..thats enough mods
Larry your work here is DONE :wink:
How do you make the hood scoop funtional without having it fly off the hood?
There are two or three threads dealing with this issue. I'll do a search and see if I can find one or two to get you started.
Old one:http://imboc.com/forums/showthread.php?t=111465&highlight=scoop+function (no photos, sorry)
To answer directly, there have been folks that added a front and center fastener to the underside of the scoop. It attaches to the underside of the front lip and has a sleeve (if I remember correctly) that goes down through the hoods' under side.:confused:
3.73 gears
t-56
shifter
real subframe connectors
aluminum driveshaft
heat extractor hood
concept rear wing
2 1/2" exhaust all the way thru
true Bullitt specific wheels like they did with the Mach instead of putting them on everything they could
mach 1000 stereo system
Is it top seven thing we HAVE done to our BULLITT or top seven changes we would have done originaly with the bullitt when ford was building it?
The only thing that really grips me about the '08 is the lack of self-return seat-backs...
all other 'niggles' are things I will change in the course of time, smoked headlights and turn signals, lowered suspension, suppercharger etc...
The visibility out the back isn't as good as I'm used to, but as an Italian friend of mine said when he bought a new Alfa Romeo (and proceeded to rip off the rear-view mirror) "who cares what's behind you!"
1 - 13 of 13 Posts
