I went to check the tranny fluid in 2445 today, and found no plug to fill it up. Is there one? And if not, how would one fill it up?
Ditto, much easier to fill from the top. Go to SVT Performance or the Mach 1 Registry and look for the sticky for CobraBob. He sells gaskets for the shifter so you don't have to use RTV to seal it back up and then you can change it even easier from then on.DHGBULLITT said:There should be a plug near the top towards the rear. I just remove my shifter and fill it from the top,being careful not to spill. Much easier i believe.
if I had a $1 for every time I heard thisMid Life Crisis #388 said:Common 01 problem. Lowering the fill level to 3.2 quarts will help the most.
Mid Life is correct. listen to him. There is a sticker to put on the tranny when Ford does the tsb. Fill line is a good bit lower than hole.installermarc said:Anyone else for ideas?
