Bob, there is a 1/2 plug on the bottom of the tranny to drain it. Use a 3/8 rachet handle to remove it. There is a refill plug on the passenger side of the tranny. You will need a hand pump which sells for about $6 bucks at Pep Boys to refill it. Takes 4 quarts even. I am running D4 with Prolong Transmission Additive and it is as good as it going get with these trannys.
John
True Blue Bullitt #2731, Bassani X Pipe w/Cats, Magnaflows (welded in), 3.73 Gears, Aluminum Driveshaft, Pro 5.0 Shifter, MGW Shifter Arm, Densecharger CAI, Superchips Chip, Steeda Underdrive Pulleys, GT Fog Lights, Tinted Windows, Stongard, MGW Pieces
<font size=-1>[ This Message was edited by: TrueBlueBullitt on 2002-01-06 10:00 ]</font>
