I installed the Steeda Tri-Ax shifter last night. The throws and precision are much improved. The shifter does transmit a lot of noise. The shift lever seems to resonate the transmission noises like a tuning fork. I think I will try installing 2 thin nylon washers between the lever and the shifter to see if that will dampen that tuning forks effect.
Overall though, I do recommend the shifter.
Brian
Brian
