When I finally do get another Bullitt I want to do a N/A engine build. As well as a driveline upgrade
The goal is to keep the stock look but have the most power (hence the reason for N/A and NOT boost)
Thinking of..
ENGINE:
5.0 Stroker Alluminum Block
Stage3 ported heads
Custom Grind Cams
Ported Intake Manifold
DRIVELINE:
Alluminum Drive Shaft
31 spline axles
Posi Differential
Gears
What am I missing that would help? Not looking for any specific hp goal...just to get as much as I can for a Daily Driver Stock looking Engine.
Thinking of..
ENGINE:
Stage3 ported heads
Custom Grind Cams
DRIVELINE:
31 spline axles
Posi Differential
Gears
