Dave, the '01 were not much different from the regular GT. I put Steeda UD's on and although the alternator pulley was the same size, the crank and water pump pullies were quite different. But that being said, the benefit was minimal.DavidMidgley said:Remember, the 01 came with underdrive pulleys. You can change them out, but your probably not getting a big benefit for the swap. At least not as much as if you had a standard GT and performed an underdrive pulley mod.
Did you document before and after? I hear mixed reviews regarding true HP gains and the willingness of the engine to spin more freely.9mmBullitt said:Dave, the '01 were not much different from the regular GT. I put Steeda UD's on and althought the alternator pulley was the same size, the crank and water pump pullies were quite different. But that being said, the benefit was minimal.
+1, real easy to do since the altenator pulley doesn't need to be changed. I don't believe there is much performance gain, but the life of the waterpump and alt will be extended if you drive in the upper RPM's from time to time. I like this idea specially when I run a few track days each year.9mmBullitt said:Dave, the '01 were not much different from the regular GT. I put Steeda UD's on and althought the alternator pulley was the same size, the crank and water pump pullies were quite different. But that being said, the benefit was minimal.
Quick question...FordFan said:+1, real easy to do since the altenator pulley doesn't need to be changed. I don't believe there is much performance gain, but the life of the waterpump and alt will be extended if you drive in the upper RPM's from time to time. I like this idea specially when I run a few track days each year.
my .02
I just opened my Steeda UDP for Xmas. I measured the Steeda set and the Bullitt set for comparison. Apparently, the factory set of UDP are VERY conservative. The Steeda set will reduce alternator speed to 79% of stock and reduce water pump speed to 68% of stock. The alternator pulleys are the same fundamental size but the crank is ~25% smaller and water pump ~16% bigger (from memory).TRUEBLUE3934 said:Does anyone know what the stock GT diameters are on the 3 pullies and what they are on the Bullitt?
I am mostly curious how much difference there is between the crank pullies? If the Bullitt crank is much bigger than the aftermarket ones, there should be some benefit from reducing that diameter.
Do you still have these?Frankenstang said:got a used Steeda set i bought off a bullitthead and never installed of anyone is interested.
