1 - 17 of 17 Posts
A few parts I have been collecting fo a chance when I can install everything. Have a few additionals on the way and on the list before I will get them all put on. I still need to get UCAs, struts, shocks, and subframe connectors.
Lists includes:
Centerforce clutch and Ford TO bearing
Ford Racing Aluminum Quandrant
Pypes SS Hangers
BMR LCAs and polyurethane isolators
OEM strut covers
BBK shorty headers
Choice for new fender badges- havent decided which to use
Stock replacement calipers- both front and rear
Goodridge SS front hoses
Rotorpros drilled and slotted rotors- front and rear
Also put the '03 Cobras from my foxbody project on the 'B
Hmm.......what else do I need?
Bullitt 736 said:
Here are some ideas.
FRPP UCA's
Cobra A arms
H&R Supersport springs
Urethane endlink kit
Urethane sway basr bushings
Urethane rack bushings
Weld up the torque boxes
MRT catted H or Mac O/R H
3-1/2" Exhaust tips
MGW or Steeda shifter
JLT CAI
SCT 3
4:10's or 3:73's
Have I spent enough of your money yet???:wink:
Lets see what I can knock off that list.
BMR UCAs soon to be ordered
MRT catted H already installed
MGW shifter-very first mod two years ago
MRT CAI installed
Predator tuner already loaded
Torque boxes will be welded when I install the SFCs
Already have the MRT tips, but will be selling them when I sale my Magnapack catback.
So a few things to be added:
H&R Springs
Assorted urethane bushings
3.73s
How do the cobra a arms help out?
Charles
My car had 100k miles so anything would have been better but the bushings are stiffer than stock, the ball joints are supposedly better and they have a better turning radius. If your car has some worn parts, this is no more expensive and better than replacing with stock parts.
Its also an easy swap when you have your springs out.
If you're going to do any drag racing with stickies you might think about 31 spline axles and diff.
Bullitt 736 said:
Since you have all the other goodies, might as well order a blower! :smile:
Blowers going on the fox body project. Cant afford to put one on the DHG#13 just yet, maybe once it get retired from DD status.
Any suggestions on shock and struts? Again mine is a DD so right now comfort is important as well as the performance. Been looking at Koni "reds"
Bilsteins FTW
Which Centerforce did you go with?
huli467 said:
Can't wait to see your car finished. Looks good.
Thanks, but its slow coming. Problem with buying parts for to cars lol, I can never decide which is more important to work on the daily driver or the project car.:confused:
That is one hell of a shopping list you've built up there! Your Bullitt is going to be sweeeeeeeet once all that is installed.
1 - 17 of 17 Posts
