MRT Street Performance Springs
Adj. Lower rear control Arms
J & M caster camber plates
Ford Racing 3.73 Gear Set
MRT Power Shifter TR-3650
Sequential Tail Light System
Are you sure that you need adjustable LCAs? Most people that I know just put them on at the factory setting and never mess with them again. If you are a hardcore racer then you might spend the time dialing in the car, but otherwise the adjustables are probably overkill. I went with the Steeda aluminum non-adjustables. They were about $100 cheaper.
Thanks for the info! I have been thinking about the adjustables for awhile now, and whether this is overkill for me. I will probably go with fixed, given the $$$.
