I'm installing an S-trim w/ aftercooler and power pipe. I bought the kit used with about 500 miles on it. Right now it has a 2.33" blower pulley that I'm obviously not going to use.
The cooler kit comes with a 3.33" pulley (which he no longer has so I have to order a new one) thats supposed to put you at about 10 lbs. I've been reading that a power pipe can add up to 2 lbs. Are a lot of people running this setup on a stock motor or should I go bigger than 3.33?
It's a 6 rib Reichard Pulley. I'd be interested in selling it.
It looks like this but its 6 rib
Yah stay with the 10 lb pully. the Powerpipe can add UP to 3 psi of boost. but the aftercooler will drop the psi so for example
10lb pulley + Aftercooler = 7 to 8 totalrun boost
10lb pulley + Aftercooler + Powerpipe = 10 maybe 11 psi totall
Thanks for the info guys!
I will order the 3.33" pulley today.
