Well after a month its finally done. The problem w/ computer ended up being the chip was programed w/ the wrong perameters and the timing was 13 and should have been 7 (the car wouldn't start w/ chip in the comp.). Had to tow it to Apex motorsports to fix it all up. After the dyno the results are as follows: Max Power 373.5 and Max torqued 365.9
They indicated that I will achive closer to Vortech's posted HP gains (420hp) by adding a bigger mass air meter. Also the fuel pump needs to be checked for either a bad conection or is to close to the bottom of the tank. Its not giving me enough fuel at 5500 rpms.
After everything I'm pleased w/ over all performace. It really cooks!
