My brother has been having problem with his 02 GT on the passenger side of the car in the backseat. It fills up with water. The front stays dry, but the back will get soaking wet. Any ideas on what may be causing it?
What he said ^^^^. If that doesn't work, try the sprinkler test while sitting inside the car. Not as effective, but sometimes the smoke doesn't go where the water travels.
ive had the 1/4 windows leak on them before...my bullitt does in the car wash...it can be either the c-pillar trim or the window itself....they are both easy to reseal as well...but if it isn't that it could be the back window or the back of the door seal. if you need any help lemme know...i do water leaks almost all day on fords
