1 - 14 of 14 Posts
Hello, Having prob.s getting it into reverse most times. It's been suggested I 1st check the level and also change to a synthetic. Any suggestions on what synthetic to use? 9Along w/adjusting the clutch)
Thanks
Mobil1 is the factory fill. I changed mine about 40,000 miles ago and it's been pretty flawless. Instant improvement!!!!!!!! and it got better over the next couple thousand miles!!! :)
I am just about due again for a change, and will do it over the winter.
a few people like all the small special nitch brands. I myself went back with the factory fill as Mobil is definetly good oil, was good enough for Ford & warranties, and is a good balance. Some of hte special fluids have too much detergent, not enough, or other odd properties. Plus I like being able to just go pick up a quart anywhere in the US should I need it.
Charles
Ford specifies Motorcraft Mercon ATF (XT-2-QDX) in their TSB for the 3650. Tremec recommended Texaco Dexron III. I've used Mobil 1 and now I have Royal Purple. It may be my imagination but it seemes like the RP transmits a little more noise. I have a TriAx shifter which is known to be a little noisy but I put it on about six months before changing to RP. The main thing is the quantity. 3.2 quarts. Do not overfill.
I refilled with Red Line D4 synthetic (which I had used in other troubled transmission applications with positive results), most important was to fill ONLY to the Tremac suggested level.
Tremec specifies Mercon III for the 3650, not GM Syncromesh. Mobil 1 IS NOT the factory fill. (See FAQs on Tremec's website.)
I honestly don't know for sure, but it has been mentioned on here that Mobil1 was the factory fill. And yes, it does require a Mercon oil in the 3650.
also I want to reiterate the need to be pretty precise on the 3.2qts.
Royal Purple here, no problems.
Amsoil is #1 in my book. Performs flawlessly on the track and the street. Never a problem.
It was in 2001.
I dumped mine because of what I perceived as "notchiness." I went with the Redline and it was almost undriveable. Went with Discount Auto Parts DexIII/Mercon and it was better. And ended up back with Mobil 1 about a two months after I dumped it in the first place. I decided notchiness was not necessarily a huge issue. It wasn't like I was missing gears.
Haven't tried the Mobil 1 yet. Tried the Redline and it was horrible. Switched to Valvoline and it was better, Royal Purple so far has been the best. Will try Mobil 1 next.
I use mobil1. I'm not 100% sure, but I think the owners manual says mobil1 for trans fluid. I'd check but I don't feel like going to the garage.:)
Now the guy from tremec told me mercon III or GM syncromesh for the 3650. I went with the syncromesh because thats what they use in there other transmissions. Seems to be fine, but I drive it really easy any way.
1 - 14 of 14 Posts
