1 - 3 of 3 Posts
Has anyone had an issue with their wiper motor and washer not working? I have power on each side of fuse and breaker. I'm hoping someone else has had this issue before, your input may help me cut down on the time I will be under the dash with a circuit tester. Thanks a bunch.
Hope somebody replies. First, if it's no too hard, try putting 12v. power directly to the washer and wiper motors to be sure one of them isn't the problem. Then check the on/off switches themselves?
With Fords, I always check to make sure the ground is good. Wiper motors are rubber grommet mounted (usually) and if the ground is bad...
Paul's advice is good as well. Do you have power at the wiper motor with switch on?
1 - 3 of 3 Posts
