This is the e-mail I received from Custom Chips: Sounds good, don't ya think????
We specialize in Fords, and we have special calibrations
and software made just for the Bullitt and it's intake. The
OEM calibration that come stock with your car was not tuned
to take full advantage of that the Bullitt's entire intake
has to offer. We can most certainly increase the
performance of your car by 15-25 RWHP and drop your quarter
mile times by as much as half a second.
As you might already know, each of our chips is built-to-
order and custom-made for each of out clients. We can
definitely build you a chip to your specific specifications
and modifications.
I have taken the liberty of including some extra
information on the CustomChip below:
*Firmer transmission shifts (for automatics)
*Removed tip in spark retard
*Remove spark reduction during shifts (for automatics)
*Revised shift pattern for more performance feel (for
automatics)
*Faster manual downshifs (for automatics)
*Higher speed limiter
*Higher rev limiter
*Higher WOT shifts
*Revised fuel table
*Revised spark table
*Improved engine braking when at closed throttle
*Improved part throttle feel from better torque converter
function
*Turn cooling fans on sooner
*Revises torque converter function to eliminate shudder and
allow it to run cooler
*Available without EGR
*Available for any air meter you want to use
*Available for any fuel injectors you want to use
*Available without rear O2 sensors
*Available for any axle ratio you are using
**Adds about 15-25 RWHP on the Bullitt (requires use of
premium fuel, regular fuel calibrations available also)
Thank You,
Joseph Santoro
CustomChip
