1 - 3 of 3 Posts
Hlp,
My name is Rick - my Bullitt #4248 was hit from behind - looking for everything from rear window back (sheet metal). Car only had 15k on the odomter.
Help !​
Wow, thats sad. if its just from the window back, any 99-04 metal will work. The pipes (tips) is what you have to make sure the body shop doesn't burn you on.
Alex
wow, good luck. Glad to see one being saved :)
as noted.. all the Mustangs are the same in that regard. Look for a 99+ and you should be fine. Note, that in 01 they switched fuel systems, so be careful if you need anything from below on a parts car.
1 - 3 of 3 Posts
